Saving in DNG o RAW
Bruno Italy
Saving in DNG o RAW
Post by Bruno Italy » 31.07.2019 09:29
Hi, I purchased the Lite version of Helicon Focus. By inserting the RAW files in the program it is possible to save only in TIFF or JPG, while if I want to save in DNG a text appears on the screen and the photograph is unusable. What should I do to save to DNG or RAW in order to develop the file later?
Re: Saving in DNG o RAW
Post by Catherine » 06.08.2019 13:58
Indeed, Raw-in-DNG-out mode is a Pro feature: https//www.heliconsoft.com/helicon-focus-versions-licensing/
With Lite version you can only save to full-res .jpg and .tiff. If you have dng selected as a saving file format in the Save window, you will be able to save to dng, but promo text will be added to the saved output and its resolution will be limited. During the trial period you've been using fully-functional Pro version, that's why you used to have this possibility then.
