Lightroom plug-in not working
walkerr
Post by walkerr »
I've installed Helicon Focus in demo mode, but I'm having trouble getting the Lightroom plug-in to work. When I look in the folder it should be in via Finder, it's present, so it installed. Unfortunately, it's not showing up in any of the likely places when I'm running Lightroom (not via a right-click context menu nor via the main menu bar under sub options to File). Any ideas? I'm running with the most current version of Lightroom Classic (8.3.1) and the most current version of the Mac OS (10.14.6).
Thanks in advance for your help.
Re: Lightroom plug-in not working
Please try the following:
1. Exit Lightroom.
2. Go to Helicon Focus menu -> Preferences -> Integration. Click the "Uninstall" button next to the LR plugin path, then click Install.
3. Exit Helicon Focus, run Lightroom, and try again
If this does not help, please open Terminal ( (Applications - Utilities - Terminal) and run this command:
sudo open /Applications/HeliconFocus.app
Uninstall and reinstall the plugin from program Preferences. Please let us know if any of the above recommendations helps solving the issue.
walkerr
Post by walkerr »
Thanks. My computer has since died, and the replacement is a week away. If I see the same problem recur with the new one, I’ll try your instructions. Thanks for your help.
walkerr
Post by walkerr »
Thanks. I'm afraid neither of those fixes worked. I'm still having the same problem.
walkerr
Post by walkerr »
I was able to resolve it. The plug-in defaulted to a "disabled" status in LR. I enabled it within the LR plug-in manager, and it now works.
MarvinLey
Post by MarvinLey »
Does reinstalling the plugin from Preferences save the previous settings at all?
Which settings exactly do you mean?
