A major bug in Helicon version 7.6.0 Windows?
TheDocAUS
Post by TheDocAUS »
There seems to be a major bug in Helicon version 7.6.0 Windows. It impacts Method C.
I downloaded the Helicon 7.6.0 installation file and reinstalled it again. But the bug still remains.
When you use Method C the stack is defective. For example, I can stack it 3 times using Method C and get materially different results each time – without changing any setting or source files. It looks like the bug impacts the setting of the white or black points or something else to do with colour, as the Histogram of each stack varies widely. Examples being uploaded to the Help Desk.
Re: A major bug in Helicon version 7.6.0 Windows?
Thank you for reporting the problem. We're investigating this now and will let you know about our findings as soon as possible.
BobStone
Post by BobStone »
Does 7.6.1 solve this issue?
Yes, it should. Once you have a chance to install and try it, we'd appreciate if you could let us know how it worked.
BobStone
Post by BobStone »
Used all methods … no problems found! And astonishingly fast, especially after the first run!
TheDocAUS
Post by TheDocAUS »
Downloading update, will test it over the next few days.
TheDocAUS
Post by TheDocAUS »
I was getting errors with Method C every 2 or 3 images. Nil so far after a dozen stacks. Looks promising.
TheDocAUS
Post by TheDocAUS »
I have done over 50 stacks and no issues so far. Bug has been squashed!
Thank you for your feedback. Please let us know if you encounter any further difficulties using the program, we'll do our best to solve issues as promptly as we can.
