Helicon fails to return output image to Lightroom
Post by el48tel » 21.05.2020 11:17
I'm running Helicon Pro. I usually send my stack as DNG from Lightroom Classic. I then process in Helicon; usually I'll make an "A" & "B" & "C" and then save these back to LR for processing.
If I make one stack into Helicon then process it and send it back to LR I have no problem.
BUT ....
I often have several stacks I want to process sequentially.
So the first image is outputted from Helicon back to LR without a problem. I select the next stack in LR; Export with previous; Process the "A" & "B" & "C"; after saving these I close Helicon ..... then I get the message that images have not been imported into LR. The files have been exported from Helicon as DNGs; they are in the folder; they are accessible; I have to "Import" them through the usual LR steps to get them for subsequent processing.
This only occurs if I process one stack immediately after the first stack. If I make one stack now, then attempt another in an hour's time I have no problem.
Re: Helicon fails to return output image to Lightroom
Post by Catherine » 23.05.2020 14:07
Does the problem persist if you use 'Export to' rather than 'Export with previous'?
Post by el48tel » 27.05.2020 20:02
Occurs with both routes
