Output file size
dsmith626
Output file size
Post by dsmith626 » 17.06.2020 21:13
I’m using an evaluation copy of the software and really impressed with how well it works with my camera (5D MKiv) and lens (100mm f2.8).
However, even shooting in raw, the output file is tiny. I’ve also tried outputting to dng. From 18 x 30mb files it produces a 5mb output dng.
Is this a limitation of try before you buy or is this normal? I don’t want to spend £200 on software that will only output files suitable for web use.
I’ve searched the forums. The only related post I can find doesn’t answer my problem, so any help appreciated.
Dave
dsmith626
Re: Output file size
Post by dsmith626 » 18.06.2020 11:39
Thanks all for the help. I think I've resolved this.
Post by Catherine » 18.06.2020 17:16
No, it's not a limitation of the trial version, it's fully functional for 30 days, equivalent to Pro version. Maybe your trial period has already expired, it that case the program goes to demo mode and it's functionality is limited indeed - low resolution and watermark on outputs. You can check if you are still running trial or demo in the main window title bar on very top, or in Help->About.
