Photoshop Support
bruno_b
Photoshop Support
Post by bruno_b » 16.07.2020 22:16
I have both Helicon Focus Pro 4 and Helicon Focus Pro 6. I still use version 4 simply because it supports .psd files. Version 6 stopped supporting .psd files. Does version 7 support them again? Thanks.
Re: Photoshop Support
Post by Catherine » 24.07.2020 09:25
No, Helicon Focus 4 for Mac (which is now 8 years old) was the only version with this feature. But you still can export the result as layers with transparency as TIFF or PNG files which likely can solve the same task you're currently using PSD for. If you try it out, make sure to try both PNG and TIFF export because they work differently (the difference is not just in the image format).
