Folder Monitor - use subfolders made by Helicon Remote?
plantfan
Post by plantfan » 07.08.2020 02:43
I just bought Helicon Remote and Focus. I am trying to use the Folder Monitor feature to process stacks as they are taken, but it seems needlessly complicated. The amount of seconds for the interval is hard to get right, and it seems like my stacks coming from Helicon Remote vary a bit in the timings for some reason, which makes it harder.
Is there any way that a feature can be added to it so that it will just separate out the stacks based on the subfolders that Helicon Remote generates, where you just tell it the amount of files that should be in each stack so it knows when to start rendering? That would seem to be easier to use than the current set-up. Thanks.
