suggestion -- faster way to select a group of files
PhilS
Post by PhilS »
A small suggestion:
Implement the standard "select all" on a Mac. That's command-a. Or implement selecting and using a folder to select and open all of the enclosed files.
rationale:
When I create a set of files to be imported to HeliconFocus, they are all in a folder, generally all by themselves. Why not make it easy to select the whole folder?
Phil
Re: suggestion -- faster way to select a group of files
PhilS wrote: 02.12.2020 17:39 When I create a set of files to be imported to HeliconFocus, they are all in a folder, generally all by themselves. Why not make it easy to select the whole folder?
Hello Phil,
this is exactly what File - Open stack does: you select any one image in a folder and the whole folder is loaded. There's also File - Open folder, which is even more straightforward, but you can't see what's inside the folder in this mode, which is inconvenient, hence Open Stack was added.
wardpartin
Post by wardpartin »
Thanks! I will work on it.
PhilS
Post by PhilS »
Thanks, Catherine, I didn't know what stack meant.
