Batchprocess only JPG files?
abgestumpft
Post by abgestumpft »
I have a folder layout like that:
Stacks (Folder)
-Stack1 (Folder)
--Image1.RAW
--Image2.RAW
-Stack2 (Folder)
--Image1.RAW
--Image2.RAW
When I add the "Stacks" folder to batchprocessor via "Add multiple folders" it will correctly add "Stack1", "Stack2",... folders to the batch processor.
But: it will add both .jpg and .RAW files for processing in each stack.
Is there a way to filter only on JPG to be used in batch processor?
I'm editing the RAW files with DXO and then process them to JPG in same folder and those should be used for stacking...
microns
Re: Batchprocess only JPG files?
Post by microns »
Right click in the folder >sort by>type
now can you can select the RAW and move them to another folder
