Where in Helicon Focus software is the location and type-size control for the "copyright" name/date now popping up? It is located at the bottom left of my image and listed in "stacked-offset" fashion, one for every image used to generate the final image. The copyright designation appears too close to the image edge, it will be cut out (cropped off) in normal printing output.
Images used in Helicon Focus first go through Adobe LightRoom where they are color corrected, adjusted, etc. Or is LightRoom the source of this copyright labeling? It has never appeared in any normal direct-from-Lightroom file.
copyright logo
erroneous copyright notice
Finally discovered - where - the copyright notice (with my name) is being added (unintentionally).
Overall processing method after Jpeg (or Raw) shooting is run the file-sequence through LightRoom to tweak, adjust or enhance images - then use LR's "Synchronize" button which brings all images to a common standard.
Corrected LR images are then - Exported (under Library) - and thereafter used by Helicon Focus. After HF's stacking is finished the "Text/Scale" tab is applied to add embossed copyright text in the lower right. Works perfect (my preference is Embossed text). But a - second - copyright also appears, tiny, white text in the - left - corner (and this one was not desired).
Culprit finally discovered: LightRoom, in the "export" stage there is a tiny check box available near the bottom which says "add copyright notice." Once I unchecked this default box... Helicon copyright text was the only text applied.
