Ianphoto
Post
by Ianphoto »
Is there a maximum file size that you can use with Helicon? If so, what is the largest size?
Cheers.
Ian
Post
by Dan Kozub »
Yes, there is a limit. Helicon Focus is a 32 bit application and cannot use more then 2Gb of RAM ( or 3G after some tuning).
We tested the program on 80Mp images which are 240Mb large in 8bit quality and 480Mb if saved to 16 bit tiff.
Most probably you will be able to process images of larger size.
Phil Indeblanc
Post
by Phil Indeblanc »
with everything moving towards 64bit for the ram problem you mention, do you think in the near future you will make a 64bit ?
(As I custom piece my new 64bit system)
Phil
