How to increase time between shots on Canon?
brentbristol
Post by brentbristol » 24.12.2011 14:43
I am shooting with a Canon 7D using an external 580EX II flash mounted on the hotshoe. Is there a way to increase the time duration between shots to allow the flash to recharge. Every other shot has a dark frame as the flash is only firing every other time.
Re: How to increase time between shots on Canon?
Post by Stas Yatsenko » 26.12.2011 11:43
Yes, you can set a pause for flash recharge in the Preferences.
brentbristol
Post by brentbristol » 26.12.2011 13:29
Thanks Stas,
Always went straight to the Canon selection under Shooting. Didn't see the options just under shooting itself. This should work much better.
