When taking big stacks (more than 100 pictures), i've came across the following issue. Sometimes (could not find yet the reason why it occurs) the 1st 15% of the image are rotated 90 degrees CW compared to the rest of the stack. Of course, HF does not like that... I've tried with or without "auto rotate live view" option, but it's the same. Any idea where it could come from ? I use a canon 5D MkII.
g0b
Image orientation
Re: Image orientation
I suspect that the images are rotated during import from the camera. I think adobe importer has such an option. You can also disable orientation sensor in the camera in the worst case.
Where can I set options for adobe RAW importer ?
g0b
g0b
I mean not the adobe raw converter but the adobe program which is listed in the window when the camera is connected.
