Best Android Tablet to use helicon remote
tanguy
Post by tanguy » 01.06.2012 14:02
I'm looking for a tablet can i use to control my D7000
( i try the asus prime tf101 - not working with adapter cable - working with the dock )
Many thanks for any suggestion
Re: Best Android Tablet to use helicon remote
Post by Stas Yatsenko » 01.06.2012 14:55
We have no personal experience with new lines of tablets released in year 2012, we don't know which tablets require a dock-station or a special adapter to connect USB devices and which don't. We know for sure Remote works with Asus and Samsung tablets, should probably work with new Acer tablets as well (but don't have a confirmation on that yet), but some of those may require dock/adapter as well.
Ed_in_LJ
Post by Ed_in_LJ » 17.07.2012 19:02
I just installed Helicon Remote on my Acer Iconotab A700 Tablet (ICS 4.0). At least all the basic functions appear to work fine with Nikon D800.
dennishh
Post by dennishh » 19.07.2012 02:59
just started using Helicon remote with a new 16 gig Nexus 7 Google tablet. All functions seem to work will be doing some studio shooting with it tomorrow and will post some more.
tanguy
Post by tanguy » 31.07.2012 12:34
and ...
your test is ok
what cable do you use to connect you tablet google to the D7000
Many thanks
Post by Stas Yatsenko » 02.08.2012 14:11
You need a OTG converter or cable which normally costs about $2-4.
Like this one:
http://www.amazon.com/Micro-USB-OTG-2-0 ... 005QX7KYU/
But first please make sure that your tablet has USB host functionality.
Guest
Post by Guest » 02.08.2012 18:11
I have been using it with a Toshiba Thrive, because of the full-sized USB Host port built-in. Works fairly well. Android 3.2 for now.
Rschlierbeck
Post by Rschlierbeck » 14.09.2012 15:32
I have personal experience with two different tablets. The Toshiba Excite 10 and the Asus Transformer Infinity TF700. Both of these tablets work fine with Helicon Remote. The Toshiba Excite has the advantage of a micro USB port. To connect to My Nikon I used a simple USB OTG cable from Amazon. Cost was about $3. The Asus also works very well but you need to buy the ASUS USB adapter. Again purchased from Amazon but more expensive. Mine cost $16.
The USB adapter on the Asus Transformer Infinity is less secure than the OTG cable on the Toshiba Excite. It doesn't stay in quite as well and feels a bit awkward. However the Asus tablet itslef is a superior experience due to the superior display. I much prefer it to the Toshiba.
Any questions please feel free to ask.
Scott
louiscar
Post by louiscar » 18.09.2012 19:08
I'm using the Asus TF700 which I got a few days ago. If you get it with the keyboard then it's full size usb slot is much more secure than an OTG adapter (which I've not tried).
Operation seems ok but have had a few issues getting it to recognise my Nikon first time I connect. Eventually it does and after that it seems to work well enough.
Post by Stas Yatsenko » 19.09.2012 11:21
Try different order of connecting the camera and starting Remote, some say it helps.
