greenish cast
rcross
greenish cast
Post by rcross » 01.08.2011 15:26
HI - I have been using Focus to create full depth of field for hundreds of gold objects. After processing in Focus, the images have developed a greenish cast that is a pain to remove and color correct. Is there any way to compensate for the cast before rendering the images?
thanks,
rob
Re: greenish cast
Post by Stas Yatsenko » 04.08.2011 12:20
The program should not introduce any color changes. I would appreciate if you upload a test stack to our server (as described at http://www.heliconsoft.com/ftp.html) so we can check this. In case you want to change the files before stacking, please make sure that all corrections are the same for all files. It means that corrections should not include "auto" or smart actions that depend on the image contents.
