Blurry Macro
LauraMacky
Blurry Macro
Post by LauraMacky » 30.05.2015 00:13
Hello there,
I'm new to Helicon and am excited about the possibilites. I've taken two different shots using the Helicon remote and my D750 with a 105mm lens. I can't figure out why parts of my image are still blurry. For position "A" I chose the center of the rose and for position "B" I chose the back part of the rose where it means the green leaf.
I used the default settings and used depth map in the helicon software to render the photo.
Anybody have any suggestions for me?
Re: Blurry Macro
Post by Stas Yatsenko » 03.06.2015 10:54
I suspect that your focus range does not cover the flower completely. The nearest petal is clearly out of focus, it looks like it is closer than the center of the rose.
You can you dof calculator from the Helicon Remote to estimate dof for given lens, camera, distance and aperture.
LauraMacky
Re: Blurry Macro
Post by LauraMacky » 03.06.2015 16:23
Ohh I see what you mean and you are correct. it doesn't. I guess I didn't realize I had to make sure that was the case first lol. Thanks much. :D
