My first try was useless
Zisko
Post by Zisko » 14.04.2019 10:45
I download the demo version of Helicon Focus to try the possibilities of the software. I use a tripod, macro rail and the camera internal focus stacking function. The results of all three algorithms was unusble. What did I wrong?
You can find the full resolution picture and the 50 RAW images in the following dropbox:
https://www.dropbox.com/sh/nvqxu31wlts6mee/AAAPiYs9dFpXQlB0l8R6-SApa?dl=0
MikeCT
Re: My first try was useless
Post by MikeCT » 14.04.2019 19:51
I’m not sure what you feel is missing. Everything seems in focus.
Zisko
Post by Zisko » 14.04.2019 20:03
I mark the artefacts in the picture. Sharpness is not the problem.
TheDocAUS
Post by TheDocAUS » 15.04.2019 11:41
Two comments, first, if they are the original jpegs they are of low quality. Second, the lighting you used is poor.
I would start by improving lighting and see whether that fixes some of the artefacts.
You need to get the overall process set up correctly, including lighting and jpg quality. Poor images in, poor stacks out.
The artefact in the middle at the back is caused by the strong specular highlights caused by your lighting, it is obvious looking at the individual images. You need to correct that aspect of your lighting by better diffusion or better placement of the light source.
Q: why are using both a macro rail and the camera's internal focus stacking function? Are we to assume the rail is stationary after the initial composition?
Zisko
Post by Zisko » 15.04.2019 14:23
I use the original RAW files (see dropbox link). The rail is only for focussing the first image in minimal focussing distance.
I will try it with less harsh light.
Post by Stas Yatsenko » 15.04.2019 15:52
Legacy method B produces better results (you can enable it in Preferences). But we would suggest to set smaller aperture to minimize blurring of out of focus areas because now you can see optical artifacts which no software is able to completely overcome.
TheDocAUS
Post by TheDocAUS » 16.04.2019 03:43
I did download from the Dropbox link, I got jpegs. Maybe I was not logged into Dropbox at the time.
