HF 7.5.1 freezing
JKTFinn
HF 7.5.1 freezing
Post by JKTFinn »
The following procedure seems the cause freezing of the program:
1: Open CR2 files for stacking
2: Start stacks with B & C method
3: Drag another set of images on the window for new stacks
4: Start stacks with B & C methods on the second set of files
5: Once the first two stacks are finished, edit the B-method result by copying parts from the C-method result
6: If I now try to save the edited B-method result as DNG, the program freezes ... if the last two stacks have not yet finished
That procedure has caused it now a couple of times. If there is no stacking going on while saving, everything works. I haven't tested, whether the editing has any effect on the freezing, it is just the way I do it.
W7 x64 with latest patches, i7 4770 S & 16 GB RAM
Re: HF 7.5.1 freezing
Please try the latest release of Helicon Focus 7.5.3:
https://www.heliconsoft.com/software-downloads/
