Ghosting and Halo
crayze_coils_1200
Ghosting and Halo
Post by crayze_coils_1200 »
hi guys i am shooting very small metallic subjects, i shoot with the canon 100D with the canon EF f2.8 100mm USM L series Macro i usually stack anywhere from 70-100 shots i am getting some ghosting around the hard edges of my stack, are there any tips someone can lend, or pointers any particular settings i dont know about whhich may help me.... hope to hear from someone soon thankyou in advance
Shane
Re: Ghosting and Halo
There is no direct and straightforward solution for this. Please try using method C or A. If this does not produce a result you are satisfied with, use method B with lower radius and smoothing values. Another option to try is using method B, then C, then going to the retouching tab and copying the problematic areas on the B result using the C result as a source.
Gjaeron
Post by Gjaeron »
please show sample images (original image with image-information) and results of your stack with identification of the affected areas
Gjaeron
