Canon 90D
Re: Canon 90D
Did you try with LiveView? My 1D X Mark III wouldn’t work with optical viewfinder but did work with LiveView.
Re: Canon 90D
I can only get it working intermittently. The 90D needs to be in Shutter Priority mode (works also in Bulb mode but this is not much use) and works more often in High Speed Continuous shooting mode. It works in either Live View or optical View but as I say, only intermittently.
Can someone from Helicon have a look at the problem please?
Re: Canon 90D
Problem solved. Set 90D in Manual mode and reduce the Aperture of the lens from maximum by a stop.
