Filename default when saving output.
When I render a stack, I see an output file in the bottom left that shows "C 2", or "A 8 2". This is a very nice, compact way to describe the method and parameters. I've attached an image showing an example, along with the Output filename template.
However, when I save the output file using that template, it generates an overly long file name showing the full words "Radius", and "Smoothing". See second attached image.
I can manually reduce each file name to something like "A 8 2", but it's not fun when doing lot's of work.
Is there any way to modify the ([PARAMS]) format to not show the words Radius and Smoothing?
- Screenshot 2021-12-09 110026.jpg (76.59 KiB) Viewed 323 times
- (210.49 KiB) Not downloaded yet
Re: Filename default when saving output.
Thank you for your input, that's a good point. We will shorten it to 'S' and 'R'.
Hoping for that change! Asked the same a few years ago ...
Thanks Catherine
