autofocus and focus stack doesn`t work
baijiemj
Post by baijiemj »
Hello, I bought helicon focus pro last weekend. But some problems have been found in the use.
1. Autofocus does not work.
When I activate autofocus, the cursor changes to focus pattern with a wait sign appears. When I click on the target area, nothing happens. My device information is as follows: macOS Monterey12.3.1, Canon EOS 1DX&5Ds & EF24-70 f2.8 II. Camera setting:one shot/single shooting/manual expose. Changing the lens cannot be solved.
2. Focus stack function does not work.
When I manually confirm the nearest and farthest focus and lock it, click start shooting, the first photo of the nearest focus will be taken normally, but there will be a problem with the farthest focus, and the actual focus will exceed the set focus point. For example, if the distance between nearest and farthest focusing options figure is 0 /8, it will jump to 28 after the shooting starts. Therefore, the farthest point is always out of focus and not sharp. Changing the lens won't solve the problem.
I look forward to hearing from you,wish you all the best.
