Capture One Import dimensions smaller
Aysgyl
Post by Aysgyl »
Hi, at the moment I am trailing Helicon and when I re-import the image back to C1 the dimensions of the image are much smaller. Is this because I am using a trail version? Thanks
Re: Capture One Import dimensions smaller
Once the fully functional period - fully equivalent to Pro license - is over, the program goes to demo mode with demo mode limitations - limited resolution of the output and watermark. In order to remove these limitations you need to purchase a license an enter the activation code to register: menu Help->Register online.
