M1 Max OpenCL
M1 Max OpenCL
Cannot initialise OpenCL on apple M1 Max computer. It returns failed. Running MacOS 12.5
Re: M1 Max OpenCL
Similiar issue on my M1 Ultra running Ventura 13.0 beta:
madking426
Re: M1 Max OpenCL
Having the same problem after the 12.5 system update.
Re: M1 Max OpenCL
OpenCL for M1 running macOS 12.5 is supported in the new update: https://www.heliconsoft.com/downloads/HeliconFocus.dmg
Re: M1 Max OpenCL
You're running a beta version of macOS, which we don't support. You'll have to either work with OpenCL disabled or install 12.5. This is because we only have one M1 system and we need it running the latest stable version of the macOS. And also because if macOS 13 continues the tradition of 12.x, we would need to ship two versions of Helicon Focus - one for 12.5 and one for 13.0, which we don't want to do.
Re: M1 Max OpenCL
Understood, thanks for the explanation!Catherine wrote: 03.08.2022 23:30You're running a beta version of macOS, which we don't support. You'll have to either work with OpenCL disabled or install 12.5. This is because we only have one M1 system and we need it running the latest stable version of the macOS. And also because if macOS 13 continues the tradition of 12.x, we would need to ship two versions of Helicon Focus - one for 12.5 and one for 13.0, which we don't want to do.
madking426
Re: M1 Max OpenCL
Waiting for update to support MacOS 12.6
Re: M1 Max OpenCL
8.2.0 has been released with 'OpenCL support for M1 with macOS 12.6' listed in the changelog
michaelezra
Re: M1 Max OpenCL
Is it safe to up update to Ventura macOS 13.0 on M1 - meaning will the Helicon Remote and Helicon focus continue to work?
Re: M1 Max OpenCL
Everything will work. Use the new version 8.2.1 of Helicon Focus if you have M1 and 13.0 (menu - Help - Check for updates also works to update from an older version).
michaelezra
Re: M1 Max OpenCL
Thank you Catherine. I thought I'd ask right here - what about Helicon Remote - will it continue working with Ventura macOS 13 ?
Re: M1 Max OpenCL
Yes, of course, Helicon Remote also works.
giovannigori
Re: M1 Max OpenCL
Hi, currently running Helicon Focus 8.2.1 on MACOS Ventura 13.1 / Mac Studio M1 Max. Helicon is seen as an Intel app, not an universal one, so it doesn't run native and I still can initialise OpenCL.
Can you help me?
Thank you in advance
Giovanni
Can you help me?
Giovanni
shutterbug
Re: M1 Max OpenCL
I updated to macOS Ventura (13.1) yesterday and I'm using Helicon Focus 8.2.1 on a MacBook Pro M1 Pro - same error message.
So it seems like it has to be fixed again, unless I'm doing something wrong.
