Hi again,
I guess I am trying to achieve two levels of batching:
First organize images that belong in the same stack by organizing the stacks in separate folders
Then do slabbing on each of the stacks
I tried to add multiple folders to the batch window, then do the split stack operation.
I was hoping it would be possible to copy this action to the other stacks in the list by using apply parameters to other stacks, but that doesn´t work unfortunately.
With a lot of stacks it is quite time consuming to do this manually.
best,
HC
