HR-A, This program is in evaluation mode
IV Photo H
Post by IV Photo H »
When starting HR android I occasionally see a pop-up saying it's in evaluation mode. Please explain this and how to get rid of it.
another question if I may. what is the proper method of shut down for the app?
Re: HR-A, This program is in evaluation mode
You need to sign in with your activation code so that the app can recognize that you have a license: menu - Sign in. Paste your activation code into the text input field.
The clean way to exit the app is menu - Exit, or simply press the "Back" button and choose "Exit" in the pop-up. But it generally doesn't matter whether you do this or not. You may as well just minimize the app and then terminate it (or let the system do it for you some time later).
IV Photo H
Thank you! Those two things were bugging me and it'll be good to have them taken care of.
IV Photo H
RE: Activation code,
HR-android was part of a sale last month which included both android and pc versions. I'm guessing then that I use the same (incredibly long) activation code for both?
PS: I was able to activate using the same code :D
Yes, it's the same. The code is 8 characters long.
