API?
Walkonclouds
API?
Post by Walkonclouds »
Before investing time and money in Helicon, I want to understand if there's an API to control the software from external sources? I want to use it in an automated rig that captures hundreds or even thousands of focus-bracketed sets, and since I'll have a developer to make our own solution to sorting and processing these images, I'd want this custom software to basically inject batches of images into helicon for processing.
Is this possible, or would Helicon require me to manually load and process each stack individually (which would take weeks).
Or, is there at least some batch function of sorts?
Thank you so much!
Re: API?
There is a command line mode which should fit your needs: https://www.heliconsoft.com/focus/help/ ... F_COM_LINE
