Moving Trees
Moving Trees
How does one deal with trees which have moved between frames of a focus stack due to wind movement. All efforts I've tried so far end up with a complete jumbled mess when trying to stack these frames. Thanks.
Re: Moving Trees
I don't think there's a good remedy for that, movement and stacks don't mix very well.
You could try using the depth map with smoothing set to a very low amount and then do some manual retouching.
