If I advance my WeMqcro rail 5 steps all is fine. If I then advance another step the software gets stuck, I think waiting for a signal from the rail.
This behaviour has just started today ! I've attached a screen shot showing the progress bar 'stuck'.
Any help gratefully received.
WeMacro rail gets stuck
- Screenshot 2024-06-25 100307.png (35.08 KiB) Viewed 26712 times
Re: WeMacro rail gets stuck
Please reproduce the problem and send a bug report (menu - Help - Report a bug). We will take a look and reply.
I assume you did not update Helicon Remote since it was last working fine?
I have sent a bug report yesterday pm.
In an attempt to 'fix' the problem I downloaded the latest version from your website and uploaded that to my computer. The issue arose with whatever version was on my pc and continued after installing the latest version.
I also contacted WeMacro in case the problem was with the controller i.e. not sending the correct signal to the Helicon Software.
I have attached their response and can confirm that the rail operates correctly with their software.
- WeMacro response.pdf
- (78.87 KiB) Downloaded 479 times
Are we anywhere near a resolution for this problem, please. ?
fdisilvestro
Hi, are you givinng enough pause between each advance command? In my experience the Wemacro rail gets stuck if it receives a new command before completing the previous one.
Regards,
Regards,
Unfortunately, it never completes the first advance !
But thanks for your advice.
