Helicon Focus 9.0
madking426
Helicon Focus 9.0
What an amazing update! Everything is lightning fast! Thank you for making this happen!
madking426
Re: Helicon Focus 9.0
One minor bug found. When in the Retouching tab, image cannot be moved with the space bar like it used to be. It brings some inconvenience when part of the shot need to be edited.
Hello, thank you! We're fixing it. In the meantime, hold the right mouse button instead of spacebar to drag the image around.
madking426
Thanks for your quick reply. Tried the mouse right click but didn't work. Strangely, the horizontal scroll wheel on the mouse worked for panning left and right but nothing happened for the vertical scroll wheel.
Windows or Mac?
Stacker0815
nice work!
I noticed this (Win11):
1. The magnifying glass (left mouse click) in the GUI zooms in further on a finished stack than in v8 (it would be nice if this were adjustable).
2. It's also extremely laggy with RAW files.
3. CLI commands (like this) don't work yet, do they? It only outputs a preview image with a watermark.
cmd = [
HELICON_PATH,
“-silent”,
“-m:B”, “-r:50”, “-s:4”,
input_folder_path,
f“-save:{output_file_path}”
best
nice work!
cmd = [
HELICON_PATH,
“-silent”,
input_folder_path,
best
I have the same problem with 9.0 - nothing I try will let me scroll at all when zoomed in during retouching. Good thing I still have version 8. Windows 11, no mouse just using the keyboard. I think it was a serious error to change the scrolling by the arrow keys to using the up and down arrow to move up and down through the image list. It was easy enough to change images before but impossible to do a good cleanup without being able to scroll around during retouching. I suggest you go back to the former system.
Hi,Stacker0815 wrote: 28.03.2026 23:35 1. The magnifying glass (left mouse click) in the GUI zooms in further on a finished stack than in v8 (it would be nice if this were adjustable).
1. We'll check this, thanks.
2. The magnifier is laggy? Or the software overall?
3. The fact you're getting the result image means your command line is correct. Do you have the Pro license? Or active trial period?
Or, get the updated version, Space now works on Windows (the Mac version will be updated later, delayed by technical issues due to updated Apple software). But you still have to move the mouse to actually pan the image.
HOLD the right mouse button and move the mouse.richardhc wrote: 28.03.2026 23:47 I have the same problem with 9.0 - nothing I try will let me scroll at all when zoomed in during retouching.
You can have both side by side.
Thank you, that's not intentional, we'll look into it and restore the keyboard controls.richardhc wrote: 28.03.2026 23:47 I think it was a serious error to change the scrolling by the arrow keys to using the up and down arrow to move up and down through the image list. It was easy enough to change images before but impossible to do a good cleanup without being able to scroll around during retouching. I suggest you go back to the former system.
Stacker0815
2. The hole image-viewer which shows the stacking result is laggy (no problem with v8 and RAWs here) i use a AMD RX 9070XTCatherine wrote: 29.03.2026 01:49 Hi,
3. Pro-license (with v8 no problems) it seams licence check is the problem then..?
4. Stacks with RAW files (i tested ARW and CR3) are broken see screenshot:
- (1.48 MiB) Not downloaded yet
Thanks. We'll check the silent mode operation, it does sound like something's wrong with the license check.
You can just keep using Helicon Focus 8 and I assume there's no image corruption issue there as well. But we don't see it on any of our computers. If you have the time to try a few things, we'd like to know if the image corruption also happens with OpenCL disabled, and with JPG source images (e. g the demo stack: menu - File - Run focus demo). And how often does the corrupted image occur? Every time, often, rarely?
Meanwhile, we'll look for more PCs with AMD GPUs to test on.
The silent mode watermark issue should be fixed now in the updated version 9.0: https://www.heliconsoft.com/downloads/HeliconFocus9.exe
Stacker0815
Hi,Catherine wrote: 29.03.2026 19:38 Thanks. We'll check the silent mode operation, it does sound like something's wrong with the license check.
1. Wow, you guys are fast. CLI now works with the new .exe!
2. I tested JPG, TIF, and RAW files, and I’m getting the same error shown in the screenshot every single time. It works when I completely disable OpenCL.
But I kept testing with photos from Nikon (Z8 and Z9), Canon (R6M2 and another model), Sony (A1), and OM System (OM-1).
All stacks show the problem except for the OM-1 files (whether TIF or RAW).
The demo JPG also works.
Maybe it has something to do with the resolution?
Let me know if you need more info or tests.
best
Thank you for the info, could you please also try with OpenCL enabled and the "Fail safe mode" checkbox ticked ON (on the same Performance tab)? Restart Helicon Focus after changing it for the changes to take effect.
Stacker0815
Tested: Enabling fail-safe mode makes no difference.
