I guess other users do the same thing. So, I'd like to suggest that you add - either to Preferences and/or via a question block that opens immediately following the merge process - the possibility to delete all the files in the stack folder once the merge process in finished.
Flush folder after stacking...
Via Photoshop, I've automated a few image corrections to all the images in any given stack (File-> Automate-> Batch). This saves me lots of time and ensures that the images to stack remain constant.
Re: Flush folder after stacking...
What if I want to process the same stack several times with different parameters? Source files will be deleted after the first processing?
