pwnell
Posts: 33 Joined: 16.12.2012 21:40
Post
by pwnell » 22.02.2014 01:53
I just got a new 6 core Mac Pro 2013 and Helicon Focus keeps on crashing after rendering a stack of 39 16-bit TIFF files in Method 4 with everything set to defaults.
This used to work fine on my MacBook Pro Retina 15".
Code: Select all
Process: HeliconFocus [2410]
Path: /Applications/HeliconFocus.app/Contents/MacOS/HeliconFocus
Identifier: com.heliconsoft.HeliconFocus
Version: ???
Code Type: X86-64 (Native)
Parent Process: launchd [207]
Responsible: HeliconFocus [2410]
User ID: 502
Date/Time: 2014-02-21 15:51:44.388 -0800
OS Version: Mac OS X 10.9.1 (13B4116)
Report Version: 11
Anonymous UUID: 159231C1-6731-A25F-5E04-A5EEE0F7E68D
Crashed Thread: 2 TaskContainer
Exception Type: EXC_CRASH (SIGABRT)
Exception Codes: 0x0000000000000000, 0x0000000000000000
Application Specific Information:
terminating with uncaught exception of type ImageFileException
abort() called
Thread 2 Crashed:: TaskContainer
0 libsystem_kernel.dylib 0x00007fff873dc866 __pthread_kill + 10
1 libsystem_pthread.dylib 0x00007fff8a29d35c pthread_kill + 92
2 libsystem_c.dylib 0x00007fff93f62bba abort + 125
3 libc++abi.dylib 0x00007fff8abaf141 abort_message + 257
4 libc++abi.dylib 0x00007fff8abd4abc default_terminate_handler() + 264
5 libobjc.A.dylib 0x00007fff938d3322 _objc_terminate() + 124
6 libc++abi.dylib 0x00007fff8abd23e1 std::__terminate(void (*)()) + 8
7 libc++abi.dylib 0x00007fff8abd1e6b __cxa_throw + 124
8 com.heliconsoft.HeliconFocus 0x00000001000f1669 BasicImageSaver::save(char const*, HLImage*, ImageFileProgressListener*) + 1529
9 com.heliconsoft.HeliconFocus 0x0000000100019e6c ImagesCache::saveImage(HLImage*, QString const&, ImageSaver::FileFormat, ProgressObserver*) + 156
10 com.heliconsoft.HeliconFocus 0x000000010001a489 ImagesCache::saveCacheImage(HLImage*, HLColorProfile const&, bool, ProgressObserver*, QString const&) + 393
11 com.heliconsoft.HeliconFocus 0x000000010000652d FocusTask::saveCaches(ImagesCache*, ProgressObserver*) + 93
12 com.heliconsoft.HeliconFocus 0x0000000100055925 TaskContainer::compileTask(Task*) + 2181
13 com.heliconsoft.HeliconFocus 0x0000000100054533 TaskContainer::run() + 243
14 QtCore 0x00000001007c86d4 QThread::setPriority(QThread::Priority) + 820
15 libsystem_pthread.dylib 0x00007fff8a29c899 _pthread_body + 138
16 libsystem_pthread.dylib 0x00007fff8a29c72a _pthread_start + 137
17 libsystem_pthread.dylib 0x00007fff8a2a0fc9 thread_start + 13
pwnell
Post
by pwnell » 24.02.2014 19:12
The latest beta from your site. I fixed it by deleting my helicon focus preferences file - seems like using migration assistant to transfer the data from my previous mac messed something up, once the preference file was deleted helicon focus just started working again.
russjb
Posts: 4 Joined: 12.03.2012 12:52
Post
by russjb » 18.05.2014 15:41
I have the same problem. How do you find and delete the preferences file?
(Also, Stas, if you're reading this, our old issue is still unresolved!)
pwnell
Post
by pwnell » 18.05.2014 18:51
I moved all files in ~/Library/Preferences/com.helicon* to the trash.
russjb
Post
by russjb » 19.05.2014 13:14
Hmm. Done that now but still crashing..
Any more suggestions?
Stas?
russjb
Post
by russjb » 26.05.2014 02:47
Just to follow-up, I finally found the *hidden* Preferences folder and deleted the prefs files, which did fix the problem.
Thanks all for the help.
GFS
Posts: 25 Joined: 08.10.2013 16:19
Post
by GFS » 19.07.2014 17:13
I'm using Helicon 6.2, having not used it at all since 6.0.18.
I'm getting constant crashes when doing several Renders of the same set of Tiff files (around 30).
Sound like I should be deleting this preference file too?
pwnell
Post
by pwnell » 19.07.2014 19:31
I went back to 6.0. It is the only one that does not crash for me on Mac Pro after trashing my preferences. Every single release since crashes. I might get one render off, but the second stack will cause a crash.
russjb
Post
by russjb » 20.07.2014 00:45
The Prefs folder, I found out, is hidden by default in Mavericks.
Make sure you find it by opening a Finder window, then clicking Go>Go to Folder, then in the dialogue, enter ~/Library/Preferences and delete any Helicon entries that you find there.
pwnell
Post
by pwnell » 20.07.2014 01:54
Makes no difference - it still crashes. And I deleted it from the Terminal so nothing was hidden.
GFS
Post
by GFS » 20.07.2014 11:07
Seems like it may be a memory issue. I get about 4 or 5 goes at different settings, then it crashes (unexpected quit).
pwnell
Post
by pwnell » 20.07.2014 19:17
Could be. Though I have 64GB and it crashes between the second and third attempts usually.
