Is there a way to use a depth map to generate a focus stack?
pitak
Post by pitak »
Hello!
Is it possible to take a depth map from a stack I already finished and apply it to the same series of images again?
The reason i ask is because I sometimes need to take a low contrast white product on white background. The helicon software sometimes has trouble making out white-on-white edges. If I could crank up the contrast and clarity temporarily to use it for a proper stack and then use the depth map on the original images, it should give me a perfect result, correct?
Thank you for the assistance!
Re: Is there a way to use a depth map to generate a focus st
Sorry, you can't reimport depth map to use second time. Please send us your stack, we will check if we can fine tune program to process such stack better.
