Using Artistic Blur, erase tool to isolate subject.
nimitz-benedicto99
Post by nimitz-benedicto99 »
Hi, here's an edited pix using artistic blur, eraser.
I applied blur to the whole image, then, erased the jumping figure.
( pix taken 23Aug2015 - L.A. )
Is it possible in the future, you include in the Artistic Blur panel the selection tool.
Mitz
edited using artistic blur, selection tool, erase
chi_8134_hf 640.jpg (269.19 KiB) Viewed 9853 times
Re: Using Artistic Blur, erase tool to isolate subject.
Do you want to make selection and then apply Artistic blur?
nimitz-benedicto99
Hi Stas,
I'd like to use Artistic blur first on an image, then, just click on selection while still inside Artistic Blur panel.
That is, no need to close Artistic Blur before going to Selection .
Or open an image in Artistic Blur, then, make selection with selection brush inside Artistic Blur panel.
It is better to make selection first. In this case unselected areas will not "spill out" to adjacent areas. If you unselect the object, the blurring will be made like this object does not exist at all.
