Movie Import for Lumix GH5
jacquesB
Post by jacquesB »
HI
I would like to open the 6k postfocus videos of the Lumix GH5 in order to merge the images in helicon focus pro unlimited
Below the infos on these videos
General
Complete name : I:\DCIM\100_PANA\P1000693.MP4
Format : MPEG-4
Format profile : Base Media / Version 2
Codec ID : mp42
File size : 108 MiB
Duration : 4s 505ms
Overall bit rate : 202 Mbps
Encoded date : UTC 2017-04-11 10:12:49
Tagged date : UTC 2017-04-11 10:12:49
PANA : ±dx6uÛó­IhóùéÝZÎÜ
Video
Format : HEVC
Format/Info : High Efficiency Video Coding
Codec ID : hvc1
Codec ID/Info : High Efficiency Video Coding
Duration : 4s 505ms
Bit rate : 201 Mbps
Width : 4 992 pixels
Height : 3 744 pixels
Display aspect ratio : 4:3
Frame rate mode : Constant
Frame rate : 29.970 fps
Bits/(Pixel*Frame) : 0.360
Stream size : 108 MiB (100%)
Audio
Format : AAC
Format/Info : Advanced Audio Codec
Format profile : LC
Codec ID : 40
Duration : 4s 505ms
Source duration : 4s 523ms
Bit rate mode : Constant
Bit rate : 128 Kbps
Channel(s) : 2 channels
Channel positions : Front: L R
Sampling rate : 48.0 KHz
Compression mode : Lossy
Stream size : 69.0 KiB (0%)
Source stream size : 69.4 KiB (0%)
Re: Movie Import for Lumix GH5
Hi. Did you try opening it? Did it fail? I'm not sure what you posted the info for.
frank_ho
Re: Movie Import for Lumix GH5 fail
Post by frank_ho »
Hello Stas
Yes - the "open video" import of a 6Kvideo with the newest Version 6.7.1 is fail.
Here you can download a (first handheld) GH-5 6K post focus video to test it.
http://www.frank-hoppe.com/TMP/P_F_0492.MP4
Thank you for fix it in a Update.
Regards
Frank
Indeed. Thanks for supplying the sample. It works in the version of Helicon Focus that we're currently developing, but not in 6.7.1. You can install the new preview version of Helicon Focus to load these videos.
For Windows: https://drive.google.com/open?id=0B_uKr ... jlObnYtQ2s
For Mac: https://drive.google.com/open?id=0B_uKr ... jlacVVrSHM
