Stacking HDR series
MikeCT
Stacking HDR series
Post by MikeCT »
Remote allows you to take several shots at different exposures for each step in a stacking sequence. Is there a way for Focus to detect this and stack all the +1EV shots, then all the 0Ev, followed by the -1EV?
Re: Stacking HDR series
Post by el48tel »
I don't think there is a way in Helicon to do this. I've just done a series like this and took advice from the Helicon Team.
It was the Helicon stacks first.
Then merge them in HDR.
Took some time to achieve --- but worth it
see
https://www.heliconsoft.com/forum/viewtopic.php?f=10&t=9869
MikeCT
Post by MikeCT »
Hi
I saw the thread, and tried to contact you, but it was locked. I will give it a try.
Post by el48tel »
Mike
https://www.heliconsoft.com/forum/app.php/help/faq#f5r0
Terry
This is easily doable, the function you're looking for is "Split stack" under Batch process (File -> Batch Process, or simply F7). Drop your entire set of HDR stacks into the batch processing dialog, press the button on the very right of the newly added row, and select Split stack -> By exposure.
Post by el48tel »
thanks
I shall try that method too
MikeCT
Post by MikeCT »
I feel foolish: I had used this to batch process a time series, I just never looked at the other options. Works like a charm. The attached is from 3 levels of exposure, 60 shots in each stacked then merged into HDR. The actual size of the flower is ~1/4" across. The full file is 72MB
