Feature request - batch processing for 4K and 6K video files
TheDocAUS
Post by TheDocAUS »
Hi
I use a Panasonic G9 and its Post focus feature, several models have Post Focus. The camera takes a 4K or 6K video around a second or two long. You then import the video into Helicon and stack the frames, Method C seems to work best. It gives a tif file around 50meg which I can then process.
The workflow is to go out and take several videos and then import each and stack them in Helicon.
It would be good if I could batch process the videos instead and then work on the stacked images. It seems batch processing only works on images.
regards
Michael
Re: Feature request - batch processing for 4K and 6K video files
I'l bump this request up on our to-do list.
TheDocAUS
Post by TheDocAUS »
Thanks Stas.
