Use Another Output as Source
bjanes
Post by bjanes »
I often use Zerene stacker and process a stack with DMap (depth map) and again with Pmax (pyramid). I then retouch using the DMap image as the target and the PMax as the source. I can't figure a way to do this with Helicon. Is there any way to do this?
Bill Janes
Re: Use Another Output as Source
Render the same stack with methods B (depth map) and C (pyramid), then select the result you want to edit. Then go to Retouching, press "Use another output as source" and select the other result.
