3D file format support & combining.
KeithSloan
Post by KeithSloan »
Hi
I saw Heliconsoft demoed at a recent Winchester Photographic Society workshop.
1) I noticed during the demo that there was an option to export a number of stacked images as 3D file.
What 3D file formats are supported? as I could not find the info on a brief check of the website.
2) Is the following possible at all?
I would like to take a series of photo's of a static object, say a vegetable and focus stack.
I would then like to use a Pluto Trigger and its dropper to capture a water droplet hitting the object.
I would plan to use the flash mode i.e. the Pluto activate the dripper and fire the flash at a set interval
after releasing the drip. I would plan to set up at least two cameras that are on bulb setting. I would then like to combine
the images of the water drops with the stacked photo's of the object to make a 3D file. Is this possible?
Re: 3D file format support & combining.
No, Helicon Focus cannot be used for such purpose. Search for a technology called photometry, you will probably find some suitable software.
