Best file format for Fuji TIFF or DNG
bobestremera
Post by bobestremera »
I see that one of your users obtained different results from using TIFF files and DNG files. The DNG files seemed to contain artifacts.
It seems I will have to convert my Fuji files into a format that Helicon can use. Which file format, TIFF or DNG, provides the most effective results in Helicon? I want my workflow to be as simple as it can be. So if there are other options, please let me know.
Bob
Re: Best file format for Fuji TIFF or DNG
If you mean Fuji 50S, only the 35 mm crop mode causes problems as it's not support by Adobe. Otherwise you can use any format and the workflow is the same or almost the same. TIFF may be a bit simpler.
