DNG Exception Loading Image: Error Code 100005
STJohnson
Post by STJohnson »
I just updated to a newer version of Helicon Focus from 6.7.1 to 7.0.2. I'm running Windows 7 (32-Bit).
When I go to render (Method B: R9, S1) the program runs for a few seconds and then at about the sixth or seventh image (.DNG files) it gives me an error reading: "DNG exception loading image: error code 100005. Compilation time 14.196 seconds"
Any ideas on how to solve this?
Re: DNG Exception Loading Image: Error Code 100005
You're running an outdated version of Helicon Focus as well as DNG converter, that's most likely whey you're seeing this failure, but you can't install more recent versions on a 32-bit system. Another possibility is that you're running out of RAM - another sore point of 32-bit systems. The solution would be to switch to a 64-bit system.
