Could you please explain what exactly you mean by not being able to connect? Do you see any error message when pairing the app with D7100?
Please see the manual: https://www.heliconsoft.com/HeliconRemoteHelp/english/network_manual.html#Nikon_built-in
Anyone else using a D7100 with the app unsuccessfully?
Chmielewskid
Re: Anyone else using a D7100 with the app unsuccessfully?
I've been using Helicon Soft with a D7100 and Nikon 200mm Macro for several years with out any problem. Sometimes you have to reset the camera to factory settings in order for it to work. I needed to do this in order to connect to a monitor via HDMI. Remember to make a copy of your current setting to a CD card before using the factory reset. Strange that you can reinstall your old settings after the factory reset and it works.
