Artefacts in output file
James Cooke
Post by James Cooke »
I am seeing lines of bright dots on some output images after stacking. This example is from 120 RAW files stacked using Method C in Helicon Focus 7.6.3. Images were shot using Helicon Remote with a Canon 5D4 and Sigma 105mm f2.8 macro lens.
(2.06 MiB) Not downloaded yet
A close up of these are shown below:
(2.52 MiB) Not downloaded yet
I also see these on the intermediate image as Helicon Focus is building the final image - see the screenshot below.
(5.78 MiB) Not downloaded yet
There is no obvious source for these artefacts on the source images. The lines on the intermediate image converge on the centre of the screen which makes me think they may be due to dust spots, hot pixels or similar.
Can you tell me what could be causing this effect?
Re: Artefacts in output file
These artifacts seem to be coming from hot pixels on the source images that turn into this kind of pixel streaks on the output during processing.
In order to check for the source of these streaks, please render the stack, zoom into the area with the artifact on the output, with high magnification, so that separate pixels can be seen, hover the cursor over the streak/dot and press F9. This will display the source image this area has been taken from and will show if you have these dots on the source images.
Helicon Focus has a dust map feature designed to deal with dust spots and hot pixels: https://www.heliconsoft.com/focus/help/ ... ml#HF_DUST
In order to create a map of hot pixels, please use dark of black background - for instance, take a picture with the lens cap on.
Please note that dust map should have the same dimensions as all the other images in the stack.
James Cooke
Hi.
I've done a detailed check for hot pixels and found they correspond with the pixel streaks on the image stack. Thanks for confirming.
I have done a pixel remapping procedure on my camera and the hot pixels no longer appear.
I will use the dust map feature in future to deal with any dust spots.
Thanks for the help.
waldenk
Post by waldenk »
i know this is a several-year-old conversation... but adding my fix here as well in case this is of use to someone.
if you're a nikon Z7 shooter, there's a very simple solution for hot pixels.
although the z7 does not offer an explicit "pixel mapping" menu option (subsequent nikon Z's do)...
all you need to do...is two "sensor clean" operations in rapid succession.
this (apparently) tells the Z7's firmware to map out the hot pixels.
i was working on a 500 image HF stack and discovered, to my disappointment, at least half a dozen bad pixels that left fairly noticeable brightly colored pixel-tracks across my stack.
two quick "sensor cleans" in rapid succession...bingo! issue resolved.
