Plugin for PaintShop Pro / AfterShot Pro
decastar
Post by decastar »
I believe PaintShop and AfterShot can use many Adobe (Photoshop/Lightroom) plugins.
Is it possible to get Helicon Focus to install as a plugin into PaintShop Pro and/or AfterShot Pro, much like it does with Lightroom?
If the installer cannot install as a plugin into PaintShop/AfterShot, is it possible to get the file that is the Lightroom/Photoshop plugin so I can try to install it manually into PaintShop/AfterShot?
decastar
Re: Plugin for PaintShop Pro / AfterShot Pro
Post by decastar »
jrjong wrote: 29.08.2020 10:04
To my knowledge, you can get the files from the lightroom and install it manually into aftershot. I'm not 100% sure though. Correct me if I'm wrong.
Quite possibly... but I don't use Lightroom.
decastar
Post by decastar »
Helicon have kindly supplied the LR plugin to try with AfterShot / PaintShop.
AfterShot Pro 3.6 - can't install the plugin - it needs to be in a special .afzplug format.
PaintShop Pro 2020 - installed the plugin, however it does not appear in the Effects > Plugins menu. I'm using the 64-bit version of PSPro, which can only use 64-bit plugins. Not sure If that has anything to do with it. I will try the 32-bit version of PSPro to see what happens.
decastar
Post by decastar »
decastar wrote: 30.08.2020 17:57 I'm using the 64-bit version of PSPro, which can only use 64-bit plugins. Not sure If that has anything to do with it. I will try the 32-bit version of PSPro to see what happens.
But Helicon Focus is 64-bit so don't think using 32-bit PSPro will do any good?
