Atempt to save Eight image focus stack gives "Write error at scanline 198"
Unfamiliar
Post by Unfamiliar »
I have an eight image stack of a mushroom so I used option C and the stack looks good but when I save I get that error. Actually the first few times I tried it the error was at scan line 0. I have done this from the stand alone app and from the Capture One plug-in but the result is the same.
I am going to try the other algorithms but is there anything else I can do? I did report the bug using the app.
Re: Atempt to save Eight image focus stack gives "Write error at scanline 198"
Are you saving this individual resulting image using "Save as...", or are you doing "Save all"?
