Heliconfocus.exe System Error on new install
pwmackin
Post by pwmackin »
I am a new user, and downloaded the 7.6.4 version of your Windows software today after purchasing the professional version.
Near the end of install a window popped up with "Adobe DNG Converter 13.0 Setup / Windows 10 and above required"
Then after closing that a second window "HeliconFocus.exe - System Error
The program can't start because api-ms-win-core-winrt-string-l1-1-0.dll is missing from your computer.
Try reinstalling the program to fix this problem."
I have downloaded the software again and re-installed with the same problem. The program will not launch and gives me the second error each time I attempt to open the software.
I am running Windows 7 SP1 with 16MB RAM. I'm a bit curious what could be causing such a problem on a vanilla install on a stable machine.
vkams
Re: Heliconfocus.exe System Error on new install
Post by vkams »
The same error on Windows 7 x64 with all updates after installing the latest version 7.6.6.
The previous version 7.6.4 worked normally.
vkams
Post by vkams »
Теперь не было ошибки при инсталляции программы, однако при установке Adobe DGN Converter ver 13 появилось предупреждение, что он только для Windows 10. Пока обхожусь предыдущей версией.
