Start and end point losing focus
Smiths_Joe
Post by Smiths_Joe »
I am using a Canon EOS 2000D with a Sigma 105mm f2.8 macro lens. I focus on the near point using the on screen arrows to set point A, using the arrows set point B, I then go back to check point A and it has moved out of focus, as well as point B moving when I go to check that.
This is a recent problem as all was working fine, no setting have changed in-between. All settings are as advised in the setup part of the FAQ's.
