Is it possible to change the order of the stack
CuSt65
Post by CuSt65 »
I have an Olympus OM-D EM-1 Mark1 and the camera makes a stack that begins first a step backwards and all steps forward. Helicon can't make a proper stack (error), because the order of the stack is incorrect. If I unchecked the first images from the stack and than there is no error but the stack doesn't look that perfect. How can I change the order of the two first images? Is this possible in Helicon?
If you need examples please let me know.
BobStone
Re: Is it possible to change the order of the stack
Post by BobStone »
A simple solution is to manually change the filenames so they are in the order you want.
TheDocAUS
Post by TheDocAUS »
I asked (off forum) for a solution some months ago. A similar problems arises with Panasonic cameras when using Post Focus. I asked for a preference where the images were first sorted by scale, then stacked, that should deal with your issue as well.
Support were interested in the suggestion, but I have no timetable for implementation
