save depth map and export layers in batch mode
hcgilje
Post by hcgilje »
It would be great if there was a way to save the depth maps and export layers for each stack when doing a batch operation.
MiB76
Re: save depth map and export layers in batch mode
Post by MiB76 »
yes, a depth map export in batch mode would also be necessary for me and my work with hundreds an thousands of stacks.
It there a way to do it?
Best,
Michael
There is currently no way to do it in batch mode, but you can with command line mode
https://www.heliconsoft.com/focus/help/ ... F_COM_LINE
MiB76
Post by MiB76 »
Catherine wrote: 12.01.2024 12:30 There is currently no way to do it in batch mode, but you can with command line mode
Hi Catherine,
thanks for your prompt reply. I will try command line mode. Comm mode should be the best solution in general.
Cheers,
Michael
