Helicon Remote Stacking issue
DpwDon Weissman-
Post by DpwDon Weissman- »
I continue to get only 2 stacked images after clicking of the nearest point and the farthest point -
This happens whether the subject is very smaller large
My Camera is a NikonZ50 set at manual - My lens is a Nikon 40mm DX macro lens set on M/A & Full
My Computer is an iMac 24"
Why do I keep getting on 2 Stacked images - How do I correct this problem
Don Weissman
Re: Helicon Remote Stacking issue
What does the "Shots" field indicate before you click "Start shooting"? Is it 2? In that case the number of shots taken will be exactly the indicated number. If you know you need more than 2, and the "Auto" checkbox is ticked, you need to calibrate the DOF calculator: https://www.heliconsoft.com/HeliconRemo ... ION_FACTOR
If you're not using the "Auto" mode then just increase the number of shots (or decrease the interval, both will have the same effect).
